Re: Re: Re: Magneto switch on M. D.
Posted by Haas on February 16, 2004 at 18:28:11 from (12.65.73.47):
In Reply to: Re: Re: Magneto switch on M. D. posted by John on February 16, 2004 at 17:21:50:
The magneto switch is in a chamber in the front end of the intake manifold. There is a cover there with a couple of screws to remove to get to the switch. If the wire is still connected to the switch, you won't have to remove the cover to check the switch. You just need a multi meter. Set the meter to resistance (ohms). Put the switch over lever in diesel and put one lead of the meter on the wire to the switch and the other to a good ground. You should read near zero ohms, or at most 4 or 5 ohms. Then change the switch over lever to gasoline and measure again. Resistance should be high, maybe 100,000 ohms or so. I think it best to have the switch working, because you don't need the plugs to be sparking when on diesel.
Post A Followup
: Re: Re: Re: Re: Magneto switch on M. D.
