Re: Starter- Pull or Push ?
Posted by TimV on February 23, 2004 at 12:52:41 from (12.39.239.130):
In Reply to: Starter- Pull or Push ? posted by John in NE on February 23, 2004 at 11:53:28:
John: It could be either way. On my folk's '42 "A", the starter is run by a foot lever that you push. On my '45 "A", the starter is run by a hand lever that you pull. Both appear to be original. The important thing is that the actual contact is made on the starter itself, and this switch will be a "normal open" (duh!!) switch that is pushed to make contact and run the starter motor. Once you've located that, the rest of the linkage could vary considerably depending on what someone cobbled up over the last 50 years.
Post A Followup
: Re: Re: Starter- Pull or Push ?
