Re: Cost to Replace Clutch in 504
Posted by rustyfarmall on February 23, 2004 at 13:27:27 from (216.248.75.135):
In Reply to: Cost to Replace Clutch in 504 posted by carl on February 23, 2004 at 12:13:35:
The only part that sounds really bad is the estimated 10-12 hours. Several years ago I worked for a John Deere dealer, the flat rate for time for replacing a clutch on a JD 4020 was only 6 hours, and yes, it could be easily done in that amount of time. A 504 is quite a bit smaller and lighter than a 4020, there is no reason in the world it should take any more than 6 hours to complete this job.
Post A Followup
: Re: Re: Cost to Replace Clutch in 504
