Re: Cost to Replace Clutch in 504
Posted by JB on February 23, 2004 at 19:18:16 from (24.157.143.220):
In Reply to: Cost to Replace Clutch in 504 posted by carl on February 23, 2004 at 12:13:35:
Hi Carl, in the last 3 years I have helped my brother replace clutch, pressure plate, throwout bearing and release bearing on 454, 495 and 684.
The cost for parts was about $350 CDN for remanufacture clutch and pressure plate plus bearings. The 684 required the flywheel to be turned and it cost $50 at the local machine shop.
Takes us about 6 hrs. When I was at IH dealer picking up the parts, there was an X IH mechanic there that now works out of his truck and does farm calls, he told me he could do the clutch job on a 684 in 4 hrs.
We use 1 bottle jack and 1 floor jack. Everyone has made excellent suggestions on the procedure.
If you decide to do this job yourself be careful.
Good luck
JB
Post A Followup
: Re: Re: Cost to Replace Clutch in 504
