Re: Re: Cost to Replace Clutch in 504
Posted by carl on February 24, 2004 at 06:24:25 from (12.2.142.7):
In Reply to: Re: Cost to Replace Clutch in 504 posted by Hugh MacKay on February 23, 2004 at 15:56:27:
I am located in central Illinois, near Peoria. The tractor is a wide front end, so it sounds like the process of splitting is a little easier.
I guess I would rather have someone else do the job, but I didn't have good feelings about the particular dealership to begin with and after hearing their estimate about the hours required to split the tracor and do the clutch and what everyone else has said here, it hasn't improved my feelings. I may call around to see if there is someone that will do it more reasonably.
Thanks for your help.
Carl.
Post A Followup
: Re: Re: Re: Cost to Replace Clutch in 504
