Re: Make Run or Paint First?
Posted by John in NE on February 24, 2004 at 06:50:19 from (170.54.59.160):
In Reply to: Make Run or Paint First? posted by Tony on February 24, 2004 at 05:50:29:
The 'C' I have was pulled out of the trees and everything was stuck.Steering,clutch linkage and engine.I started with a power washer,then tore it down, rebuilt everything,overhauled engine assembled the tractor,got it running,tore it back down and then I painted it. Now I am working on a F-20 for a friend,I tore it down completely and am in the process of putting it back together to get it running.I did paint the bell housing and inside the frame rails so I won't have to remove the engine to paint them after it s running.Theres not much to paint on a F-20,that needs to be done before it is running so by all means,get it running first.John
Post A Followup
: Re: Re: Make Run or Paint First?
