Farmall Super A or Straight A
Posted by Jon on February 24, 2004 at 18:14:40 from (68.9.29.252):
I put a picture of this tractor under tractor photos. You can also e-mail me if you know what it is.I am trying to figure out if this is a Farmall Super A or a straight A because The serial number Apperes to be a super A the block has the hyd port for hyds for a super A wich only some Farmall A had. It says that it is yellow from the factory. But it has a weird hyd system on it like I have never seen before can you help me figure out if the is a super A or a regular A or is it something special???
Post A Followup
: Re: Farmall Super A or Straight A
