Re: JB Weld on a cam
Posted by Larry in CO on February 24, 2004 at 19:58:46 from (32.97.110.142):
In Reply to: JB Weld on a cam posted by Digger on February 24, 2004 at 19:29:21:
If you can't find a good used one, you should be able to have your cam built up and re-ground to specs. I've had good luck having this done on car engines before. Good luck. Larry
Post A Followup
: Re: Re: JB Weld on a cam
