Re: JB Weld on a cam
Posted by Michael Soldan on February 24, 2004 at 20:14:32 from (216.46.130.21):
In Reply to: JB Weld on a cam posted by Digger on February 24, 2004 at 19:29:21:
Digger, your local auto supply shop will have a machine shop or connections to a shop that can built up a cam and re grind it to specs. In our shop we have a supplier , Ideal Supply, whose machine shop does this kind of work for us and they guarantee the job is as good or better than original because of the tempering process. I personaly would not put a motor back together with JB weld as the source of the fix...good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: JB Weld on a cam
