Farmall Tractors Discussion Board
Re: 684 Power Steering
Posted by ltf in nc on October 17, 1999 at 16:44:24 from (206.228.213.32):
In Reply to: 684 Power Steering posted by Plant Doctor on October 17, 1999 at 16:13:38:
This tractor gets its hydraulic pressure for the power steering from the same source as the power brakes. There is a somewhat complicated arrangement of check valves, control valves and relief valves in a housing near the hydraulic oil filter back of the left running board. These adjustments are sensitive but the problem is usually a broken spring or trash clogging an orifice. If you have not already changed the filter do that first and check the fluid level. I do not suggest that you do any experimental adjustment to the valve system without some support from an experienced person and/or a good manual.
Post a Followup
: Re: Re: 684 Power Steering
