Re: I-140 rear axle removal
Posted by TDK on February 27, 2004 at 14:23:59 from (205.188.209.82):
In Reply to: I-140 rear axle removal posted by Al Schuman on February 27, 2004 at 10:08:30:
Al,
I forgot to tell you to remove bottom pan. Then hold drive gear with pry bar; tap axle in and out until it breaks loose from gear. It will take more than just a pull, use a brass punch or wood block. Looked in the manual this time, this should work.
Post A Followup
: Re: Re: I-140 rear axle removal
