Re: 684 has Low side TA only
Posted by JB on February 28, 2004 at 10:29:40 from (24.157.143.220):
In Reply to: 684 has Low side TA only posted by wolfy on February 27, 2004 at 21:20:52:
Hi I have been told by an IH mechanic that the Hi side of the TA is controlled by a hydraulic clutch run by a separate hydraulic pump that runs off the PTO shaft. The Lo side is a mechanical sprag clutch with a friction disk to prevent free wheeling on down slopes. The separate hydraulic pump can be accessed thru the inspection hole in the bottom of the torque tube. This pump gets its hydraulic oil from the transmission and returns it into the line that goes to the oil cooler in front of the rad. There is a check valve inline with the Hi clutches to hold the hydraulic pressure on the clutches when the engine is off to prevent run away on a slope. This valve is sometimes at fault being stuck or clogged. The function of this hydraulic pump can be checked with a pressure and flow meter by tapping into the hydraulic pipes by the left brake pedal and under the battery box. I have been doing some research on the 684 TA as my brother's 684 TA has started to: 1) in Hi not hold on hills with engine off. 2)sometimes in Lo if you go down a small incline when you get to the bottom it stops and you must depress and release clutch to start again. I believe the only harm you will do running in Lo all the time is wear out the friction disks, if you go down hills with heavy loads behind. There are a few IH mechanics that contribute to this board and can added some additional advice. Lets us know the out come. Good luck JB
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
