674 Engine Balancer Timing (D239)
Posted by J.T. Britt on February 28, 2004 at 15:15:06 from (69.40.53.138):
The I&T manual states to locate No. 1 piston at TDC on the compression stroke.Locate mark on crank gear with the mark on the balancer gear.The only way i can get the marks on the crank gear at the bottom where i can see them is to put No. 2 piston at TDC.
Please help me.There must be something im doing wrong somewhere along the process.Thanks A-LOT.
Post A Followup
: Re: 674 Engine Balancer Timing (D239)
