Farmall Tractors Discussion Board
Re: Hydraulic Oil and ?
Posted by Phil Auten on October 18, 1999 at 05:35:33 from (206.175.72.226):
In Reply to: Hydraulic Oil and ? posted by MrGadget on October 16, 1999 at 12:00:30:
Mr.G,
The water you drained is probably condensation, and no, Hy-Tran will not absorb it. The only fluid I can think of that will absorb water is brake fluid, which is alcohol based. Personally, I would follow Farm-Al's advice and drain/refill the whole thing. A lot cheaper than a rebuild. Like the ad says, "you can pay me now or you can PAY me later".
Post a Followup
: Re: Re: Hydraulic Oil and ?
