Need help w/Select-trac / Select-a-valve Hydrolics
Posted by Pete in PA on March 02, 2004 at 16:34:29 from (134.192.251.153):
Hi all,
I'd like to install one of these select-a-valve units on my 1940 "H". Does any one here use one? What are they best used with? Any pictures of an installed unit would be helpful, or even detailed descriptions. Thanks in adavnce...
Pete in PA
Post A Followup
: Re: Need help w/Select-trac / Select-a-valve Hydrolics
