Farmall Tractors Discussion Board
Re: Hydraulic Oil and ?
Posted by MrG:OK, so I drain it, then what? on October 18, 1999 at 10:55:00 from (216.170.12.242):
In Reply to: Hydraulic Oil and ? posted by MrGadget on October 16, 1999 at 12:00:30:
If I drain the reservoirs from as many plugs as I can find, what about the oil that remains in the system, i.e. the pump and lines? If it's not the same type oil as what I put back in, will it mix and function properly? What if the lines DO drain, how do they refill? Under pressure, or do I have to bleed the air off somewhere?
Post a Followup
: Re: Re: Hydraulic Oil and ?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
