Re: Super A Power Steering
Posted by potosi on March 05, 2004 at 16:37:17 from (69.29.12.37):
In Reply to: Super A Power Steering posted by Terry on March 05, 2004 at 16:13:26:
Yes you can.I added it to a 140 which is the same.Use a Char-lynn hyd. motor in the steering shaft,cut the hyd. manifold lines,with hyd.hoses run the pressure line to a pressure regulator then into the hyd.motor,out of the motor and return to the pressure reg. then back to the return pipe of the hyd.manifold.I used iron pipe fittings brazed to the hyd.manifold.I know that I didnt make it very clear, however maybe it will help you. Lynn
Post A Followup
: Re: Re: Super A Power Steering
