Super A-making hydraulics stronger-log splitter
Posted by Don Green on March 07, 2004 at 02:40:17 from (152.163.252.227):
I was looking at some specs.on the pump and it seems like it may be capeable of over 1500 psi.Can anything be done inside the hydraulic unit to give more psi to the lifting arms,like messing with a relief spring or something?I rigged a crane like setup on the back to move heavy junk laying around and it needs a bit more power.Also is it capable of running a log spliter with the stock pump.Can the pump be "worked out"?the engine is shurely big enough for the job.Are there any prouducts available to make tapping in to the pump easier?-don
Post A Followup
: Re: Super A-making hydraulics stronger-log splitter
