Re: Re: Re: Re: C123 engine overhaul max HP
Posted by Stan(VA). on March 09, 2004 at 13:00:04 from (69.19.0.1):
In Reply to: Re: Re: Re: C123 engine overhaul max HP posted by Brown Dirt Cowboy on March 09, 2004 at 09:17:20:
Yes, Tom. I've done a few also. My point was just to say it isn't as easy as buying the 3 1/4" sleeve set and popping them in. On the early C123 blocks, that can be done easily as an in-chassis overhaul. All the others have to come out and go to the machine shop, then you need to come up with a solution for the O-rings.
Stan(VA).
Post A Followup
: Re: Re: Re: Re: Re: C123 engine overhaul max HP
