Re: Surging H
Posted by Paul in Mich on March 09, 2004 at 18:22:28 from (68.188.227.110):
In Reply to: Surging H posted by Jeff on March 09, 2004 at 15:34:46:
Jeff, Your carb, if not adjusted properly, may run too rich or too lean, but it is doubtful it would cause surging. Surging is usually attributed to governor problems, either broken or weak spring. It could also have a restriction preventing it from operating properly. YOu can open the governor housing by removing the bolts on the side of the housing. If it needs adjusted or parts replaced, refer to the service manual for the proper procedure.
Post A Followup
: Re: Re: Surging H
