Re: What to do about overheating?
Posted by Bob M on March 11, 2004 at 13:55:43 from (165.170.128.66):
In Reply to: What to do about overheating? posted by SAm in NS on March 11, 2004 at 13:24:26:
Sam – I’m presuming Super A does not have a water pump? If so, problem is the higher friction resistance from the smaller tubes in the recored radiator is keeping the thermosyphon effect from flowing enough water to cool the engine under load.
Easiest solution is probably to swap the small tube radiator for one with the correct (big tube) core. Or you could install an add-on water pump kit.
I presume you've already checked for an obstruction inside the radiator/hoses, that the fan belt is not slipping, etc...
Post A Followup
: Re: Re: What to do about overheating?
