Re: 100 oil leak
Posted by Hugh MacKay on March 13, 2004 at 16:55:51 from (216.208.58.146):
In Reply to: 100 oil leak posted by JEEPER on March 13, 2004 at 15:31:25:
jeeper: It is quite a job as the entire front has to come off tractor in front of engine. Then the crank pulley must be pulled as it is pressed on. This pulling requires care, and you should post that one as a specific question. I have never done it however several on here have.
When you get this repaired, remember the most common cause of this failure is over filling with motor oil. I run all my offset Farmalls, never closer than 1/4" to and below the full mark. I never add oil until below the add mark. Most engines will do this to some degree, but the C-113 and C-123 are especially prone to seal failure both front and rear, if too full of oil.
Post A Followup
: Re: Re: 100 oil leak
