Re: IH 2001 loader Will it fit a Super M??
Posted by Hugh MacKay on March 13, 2004 at 17:30:55 from (216.208.58.146):
In Reply to: IH 2001 loader Will it fit a Super M?? posted by Jonesy on March 13, 2004 at 16:40:06:
Jonesy: The 2001 loader will make a good loader for your Super M You will likely need to do some fabrication where it bolts to tractor. Some will try to tell you it depends whether it came from a Farmall or Utility. Yes in the parts book it will show differeny part numbers on sub frame for different tractors. The difference is just the actual mounting point, and fabrication will correct that. Over the years I have moved numerous loaders from row crop to utility tractors and vice versa. They aren't as different as most people would have you think.
On the $1,500. price tag; check for cracks on frame, wear in the pins and try and get the hydraulic rams extended, enableing you to see their condition.
Post A Followup
: Re: Re: IH 2001 loader Will it fit a Super M??
