Re: Farmall A Generator Question
Posted by Bob M on March 15, 2004 at 06:17:21 from (165.170.128.66):
In Reply to: Farmall A Generator Question posted by Maurie (MI) on March 15, 2004 at 04:47:29:
Maury - Wiring should be like this:
- Generator "A" terminal to regulator "GEN" terminal
- Generator "F" to regulator "FLD"
- Regulator "BAT" to ammeter
- Regulator "L" to ignition switch & light switch power supply terminals. (If the regulator has no "L" terminal make the ignition and light power connection to the regulator "BAT" terminal.)
To swap ground simply reconnect the battery for positive ground then momentarily jumper the BAT and ARM terminals at the regulator. If the ammeter reads backward afterward, simply swap the wires at both ammeter terminals.
Post A Followup
: Re: Re: Farmall A Generator Question
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
