Farmall A Generator Question
Posted by Maurie (MI) on March 15, 2004 at 04:47:29 from (199.176.235.66):
Friend of mine just bought a '44 A. Previous owner did some "work" on the wiring. Resistor in the 4-position switch was shot so he replaced what I assume was a cut-out relay with a voltage regulator. Basically, we just want to make sure his wiring isn't like some of the other "work" he did on the tractor. I've got wiring diagrams, but I need to know which terminals are which on the generator and voltage regulator. No markings are visible on either. He also managed to hook things up negative ground. Want to get this back to positive ground and make sure the wiring is correct before we tear into some of the other projects. Thanks.
Post A Followup
: Re: Farmall A Generator Question
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
