Re: Farmall A Generator Question
Posted by Maurie (MI) on March 15, 2004 at 11:54:07 from (199.176.235.66):
In Reply to: Farmall A Generator Question posted by Maurie (MI) on March 15, 2004 at 04:47:29:
Thanks Guys. The resistor on the 4-position switch is definitely shot, so I assume that what he has is a voltage regulator mounted on the generator and not a cut-out. We've looked long and hard and can't find anything stamped into the generator or marked on the regulator. Must be an older style regulator since it has a metal cover rather than the bakelite type. I've got Bob M's wiring diagram, so once I identify the terminals, should be able to get things hooked up. Glad you mentioned re-polarizing the generator, that one might have slipped past us.
Post a Followup
: Re: Re: Farmall A Generator Question
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
