Re: Delco alternator
Posted by moonlite on March 16, 2004 at 14:59:13 from (64.82.207.5):
In Reply to: Delco alternator posted by Ron 1456 on March 16, 2004 at 14:30:23:
Today i bought two at a local wrecking yard. The owner was going to give them to me but i gave him a $5 tip. Took to a rebuilder one was good one needed diodes. Will have diodes put in one and use the other as is. I do not like one wire as well because it takes higher RPM to get them started. Anyway the 3 wire is ok for here as it is on a 574 Diesel
Post a Followup
: Re: Re: Delco alternator
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
