Re: C Steering Question
Posted by TDK on March 16, 2004 at 19:40:43 from (64.12.97.12):
In Reply to: C Steering Question posted by Gary_N_WV on March 16, 2004 at 15:07:59:
You're are correct in your description, nut holds bearing & retainer holds brg. in housing. Remove retainer,make sure nut on shaft is tight. With retainer removed, hold outer race of brg. with something(screwdriver,etc.)& have someone rock steering wheel back & forth while watching shaft and brg. movement. You should be able to determine if brg. is worn out,good possibility,while doing this.
Post a Followup
: Re: Re: C Steering Question
