Re: intalling step head pistons in an (h)
Posted by justin on March 17, 2004 at 06:00:19 from (12.34.184.144):
In Reply to: intalling step head pistons in an (h) posted by Jonathan Mirgon on March 16, 2004 at 22:55:43:
Unfortunately you may run into a situation where you cannot use the step head pistons in the tractor due to the cylinder head. The steps on the pistons are designed for the specific cylinder head used on the model of tractor, and you may run into a situation where the piston will touch the top of the cylinder head. Take careful measurements of the pistons before you install anything, as you may have to install flat tops.
Post a Followup
: Re: Re: intalling step head pistons in an (h)
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
