Re: farmall H rod + bearing clearence
Posted by riverbend on March 17, 2004 at 19:40:11 from (208.160.33.239):
In Reply to: farmall H rod + bearing clearence posted by Jonathan Mirgon on March 17, 2004 at 17:46:11:
You seem to be making pretty good progress on this motor. Connecting rod bolts should be torqued to 40 ft lbs. If you do not have the lock tabs, be sure to use something like blue locktite. The bearing clearance is 0.002 to 0.003", same as the main bearings (those bolts are 75 ft. lb.). Rod shells (mains too) go in clean and dry. Oil the bearings surfaces after you check the clearance with plastigage. With the rods and pistons installed, the crank may be hard to turn, but it should turn smoothly, without any tight spots. I had to fiddle around with the mains and rod caps to get the crank to turn smoothly. It helped to use two 0.005" feeler gauges on the same side of the joint. Be sure the crank turns smoothly on the mains before you bolt up the rods. The IH Service Manual for H from Binder Books very useful for this part of the assembly.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
