Re: Help on SMTA water pump
Posted by 49 Cubber! on March 20, 2004 at 10:09:47 from (206.74.216.141):
In Reply to: Help on SMTA water pump posted by Keith on March 20, 2004 at 07:42:40:
Dont know on the SMTAbut if the pump is similar to the M pump,it can easily be rebuilt, Iwouldnt just put new seals in,change the bearings as well.If the impeller shaft is worn,youre beter off getting a new pump.Unless things have changed in the last couple of years,those arent available new,and I was told by someone,that good used ones were real high.I ended up buying a good used pump and rebuilding it.
Post a Followup
: Re: Re: Help on SMTA water pump
