Re: Putting it all back together....harder than ex
Posted by Haas on March 21, 2004 at 06:53:51 from (208.180.178.57):
In Reply to: Putting it all back together....harder than expect posted by Tommy H on March 19, 2004 at 19:18:56:
Sounds to me like you don't have the slots in the rocker arm shaft lined up with the bolts. If the slots are lined up, you should not have to force the rocker assembly. If you look through the rocker assembly retaining hole, you can see the shaft. Turn the shaft until the slots are lined up with the hole. When I went to work on my C, some previous owner had forced the rocker assembly on without lining up the slots. It took much prying, choice words and more than an hour to get it off. With new stud bolts and the shaft turned correctly, the assembly slides right on. (and back off when you need to do it)
Post a Followup
: Re: Re: Putting it all back together....harder than ex
