Re: Need an Axle Clamp for a Farmall 656 tractor
Posted by Michael Soldan on March 23, 2004 at 15:29:02 from (216.46.130.17):
In Reply to: Need an Axle Clamp for a Farmall 656 tractor posted by Harry on March 23, 2004 at 12:48:06:
Harry, I think you should heat that clamp up red hot and then douse it with cold water..lots of cold water at once to cause the quickest contraction of the heated metal..I will guaratee you that the rust and corrosion will break loose and you will be able to put some penetrating oil on it and turn it. I believe that the axle clamp is the same on H's and M's and any tractor wrecker in your state should have them..there are likely several other Farmalls that use the same axle clamp...ie) the same size axle..I did manage to break one one time and my local wrecker had another for the big price of $5...I had heated it red hot and was pulling on it with a Johnson bar and I guess it cooled too much before I got it out and I snapped a bolt off, the extraction more costly and time consumming than a replacement. Good luck from Mike in Exeter Ontario
Post a Followup
: Re: Re: Need an Axle Clamp for a Farmall 656 tractor
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
