Re: Shelf Life of Diesel Fuel?
Posted by Jed on March 25, 2004 at 08:43:37 from (66.212.143.210):
In Reply to: Shelf Life of Diesel Fuel? posted by Spence on March 24, 2004 at 20:11:52:
Diesel fuel with a stability additive will be okay out to about 1 year, after that it begins to revert back to a heavier chemical state. Gums begin to form as the fuels oxidize. Also bacterial growth, both areobic and anaerobic will begin. The fuels all age differently, so it is hard to pin it down, but testing such as accelerated stability , etc. can tell you what you might expect. I would use it up before too much longer.
Post a Followup
: Re: Re: Shelf Life of Diesel Fuel?
