Re: w6 Gas Tank
Posted by MN Charlie on March 25, 2004 at 10:28:03 from (134.29.138.6):
In Reply to: w6 Gas Tank posted by Bill Newton on March 24, 2004 at 18:34:50:
I just went and looked at the W-6 gas that I just found this winter, I'm trying to make it run, it has sat in a shed for over 10 years that I know about and maybe even longer. The engine turns and the fuel tank is dry no rust or varnish. I see that I will need to find a "better" rear rim.
I went and looked at the fuel tank and it's made just like an M with the hooks welded on the front for the J hooks to catch on. I hope this helps, good luck.
MN charlie
Post a Followup
: Re: Re: w6 Gas Tank
