Farmall Tractors Discussion Board
Re: Re: Motor oil in 140 hydraulics reservoir?
Posted by Curt Cooke on October 21, 1999 at 05:53:28 from (207.75.224.250):
In Reply to: Re: Motor oil in 140 hydraulics reservoir? posted by ddg on October 20, 1999 at 16:50:28:
Use only IHC HY-Tran fluid. If that's a problem, you have a problem somewhere else and should fix that but motor oil is not a good hydraulic oil. It doesn't deal as well with condensation, it tends to foam, get too thick in the cold; just not a good deal all the way around.
Post a Followup
: Re: Re: Re: Motor oil in 140 hydraulics reservoir?
