Re: Re: Re: C parts hunt, found em all! heres the
Posted by CNKS on March 25, 2004 at 20:21:25 from (207.178.96.213):
In Reply to: Re: Re: C parts hunt, found em all! heres the lis posted by Tommy H on March 25, 2004 at 20:13:22:
Be sure that the pump is not leaking hyd fluid into the crankcase. This is a common problem and sneaks up on you. Pull the pump and replace the seal, if the shaft has a groove, you need a speedi sleeve. If the seal is an o-ring, and there is a groove, you have to have the shaft hole enlarged to accept a speedi sleeve. Seals are one item that is overpriced at your Case-IH dealer. A good bearing shop can cross reference or match most of them at 1/2, 2/3's the IH price. Same seal, same brand.
Post a Followup
: Re: Re: Re: Re: C parts hunt, found em all! heres the
