Farmall Tractors Discussion Board
Re: Motor oil in 140 hydraulics reservoir?
Posted by Brian thanks on October 21, 1999 at 14:46:56 from (216.40.143.140):
In Reply to: Motor oil in 140 hydraulics reservoir? posted by Brian on October 20, 1999 at 15:17:50:
Thanks for all of your input. I agree with all of you. Ideally, I would only put in hydraulic fluid. However, I suspect that the seals currently leak. So I think I should see a great improvement if I go to non detergent 20w. I suspect that currently it has 30w detergent oil.
My thinking is that a little 20w leaking into 10w 30 detergent motor oil won't hurt anything for a little while under the light use I give this tractor. Would I do it in a car? No. But I am thinking that hydraulic fluid would be worse in the crankase.
Post a Followup
: Re: Re: Motor oil in 140 hydraulics reservoir?
