Re: 3 Point hitch on H
Posted by Road Warrior on March 27, 2004 at 19:11:09 from (216.174.170.143):
In Reply to: 3 Point hitch on H posted by Farmall Ed on March 27, 2004 at 18:28:00:
Sounds like you don't have everything you need for a proper fix. Most cylinders use "back-up rings" on each side of the o-ring. It's just a flat nylon or plastic type ring that is cut open in one spot. It takes up space in the ring groove to keep the o-ring seated and prevents it from rolling. Take your cylinder to a hydraulic shop and they should be able to fix you up with whatever you need.
Hope this helps.
Post a Followup
: Re: Re: 3 Point hitch on H
