Re: Re: H belly pump pressure?
Posted by CNKS on March 30, 2004 at 19:15:21 from (207.178.96.214):
In Reply to: Re: H belly pump pressure? posted by mike in PA on March 30, 2004 at 18:57:07:
267057-up had the 800 psi pump. That would be late 1947. A 9 foot disk is too much for an H to pull, unless you run very shallow. 6-8 is more like it, if you want any depth (I assume you mean tandem disk). If it is a wheel controlled disk, I imagine it would lift it. If you mean 3 point, the front end will come up.
Post a Followup
: Re: Re: Re: H belly pump pressure?
