Re: Adding fenders to an H
Posted by Larry in CO on March 31, 2004 at 17:06:33 from (32.97.110.142):
In Reply to: Adding fenders to an H posted by riverbend on March 31, 2004 at 16:35:57:
Riverbend,
I had the same problem as you with the extension mounting plate covering the original zerk. Napa sells zerks that have the fitting mounted about 45 degrees off, which will allow you to grease the rear bearings. They work pretty slick. HTH Larry
Post a Followup
: Re: Re: Adding fenders to an H
