Re: Hydraulic question
Posted by Hugh MacKay on March 31, 2004 at 20:05:45 from (209.226.106.132):
In Reply to: Hydraulic question posted by Tim on March 31, 2004 at 18:59:20:
Tim: I'm not right up on these 74 then 84 series tractors. However by the time they came along all the Farmalls had a float position on their hydraulic lever and valve. With the single hose you had to be sure you pluged into the right port for that to work. On the Farmall all you need do was put your lever in float, when lowering an implement. With the Farmalls that would have started in 63 with the new 04 and 06 series. 74 series was at least 8 years after that, it must have it.
Post a Followup
: Re: Re: Hydraulic question
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
