Re: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE
Posted by Greg on April 07, 2004 at 08:09:42 from (4.227.121.25):
In Reply to: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE posted by jdemaris on April 07, 2004 at 07:58:59:
My 364 still has it's original BD154 engine and it has a "piggyback" style hydraulic pump mounted on the right side of the engine, driven off the gears in the timing cover. They call it "piggyback" because it is 2 hydraulic pumps mounted back-to-back and actually independent of each other but they suck out of the same reservoir. the back pump just services the power steering cylinder while the forward pump services the lift. It's all factory original. My power steering cylinder sits on the left side of the tractor somewhat parallel with the tractor. It doesn't have a mechanism under the steering shaft for the power steering such as Fords and JD's I've seen.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE
