Re: Re: Re: Re: rear wheels on super A
Posted by Bud on April 07, 2004 at 09:06:57 from (152.163.252.227):
In Reply to: Re: Re: Re: rear wheels on super A posted by Hugh MacKay on April 07, 2004 at 08:47:10:
I bet your right--the overall mass of the larger cast wheels probably dampen out any effect from the offset engine. I was looking at my SC and SAV side by side and I bet the SAV wheels are significantly heavier. In fact I would think the SAV wheels without weights would outweigh the SC's with a set of weights.
Bud
Post a Followup
: Re: Re: Re: Re: Re: rear wheels on super A
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
