Re: Serial number question on Super C
Posted by Stan(VA). on April 07, 2004 at 13:34:41 from (66.82.9.58):
In Reply to: Serial number question on Super C posted by BillWV on April 06, 2004 at 20:43:22:
Bill,
the 3xxxxx is 354898 (block casting number), Rev level should be 1 or 2, probably an R1 for 1952. The engine serial number is stamped (not cast) on a small flat to the upper right side of the block above the distributor/governor area. The engine and chassis serial numbers were not matched on these models, engine number typically higher that the chassis number. FWIW, my 1952 Super C is chassis num 146xxx and the engine number is 148xxx.
Stan(VA).
Post a Followup
: Re: Re: Serial number question on Super C
