Re: Re: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE
Posted by jdemaris on April 07, 2004 at 18:55:17 from (209.23.30.173):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: 414B ENGINE posted by Greg on April 07, 2004 at 07:59:52:
I assume you're going to use the Delco 10 or 12 si, it's the most common for this purpose - although I've been using Hitachis lately, taken of older Subarus. They have the same hookup, but are much more compact. Anyway, the alternator has the main battery post, and then a harness plug connects to the top of it and it has two terminals, #1 and #2. #1 goes to switched current, i.e. hook it to the IGN terminal of the ignition switch with at least 16 gauge wire, as long as you have a diesel and not a gas engine. If you want to install a charge indicator light, put it in line between the #1 terminal and the IGN on the ignition switch. #2 terminal on the alternator is for "voltage sensing." It tells the internal regulator what voltage is at the battery. On a machine where there is a long run of wire, this wire would go to the postive post on the battery because the voltage there can be slightly different than at the alternator. For hook up on your tractor, you can just connect it to the large post on the alternator - so just put a jumper wire from #2 to the large BAT post, maybe a 2" or 3" piece of 16 gauge wire. Now, that large BAT post on the alternator goes to the positive post of your battery. It needs to be heavy wire, at least 10 gauge, but 8 is more adequate. Your ammeter goes in line with this wire, i.e. somewhere between the alternator and the positive battery post. A few notes: You don't have to actually hook this big wire on the battery post if there are better places that are closer. On some tractors, it can be put on the starter relay or switch post if you have one. What ever you hook it to, it must eventually hook to the positive battery post and must be at least as heavy as the 8 or 10 gauge wire. Some tractors, cars, etc. don't use direct reading ammeters anymore. The reason being it entails using too much wire. On your tractor it probably won't make a big difference. On a car or truck, the big charge wire would have to run a long, long way. So, in those cases either volt meters are used - which don't need heavy wire, or "shunt-wired" ammeters are used. They give a representative reading. In general, a shunt-wired ammeter that shows 30 amperes of charge might only have 3 amps flowing though it, so it only allows a fraction of the available current to flow through it, and therefore uses a small wire, but lies to you and pretends it's doing more. In the end, you are still seeing an acurate reading, it's just kind of lying to you for your own good. I probably told you more than you want to hear.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
