Re: 756 Diesel is Hard Starting
Posted by Brian on April 07, 2004 at 18:58:34 from (12.37.227.203):
In Reply to: 756 Diesel is Hard Starting posted by Dennis on April 05, 2004 at 16:38:17:
I used to work on the fuel systems for these tractors a couple years ago. Yes, they can be rebuilt and yes it's not cheap. But it's far cheaper than a new pump. Also the injectors need to be looked over closely and not just reset. Compression should be around 300 psi on a cold engine. Make sure the valve lift is correct as this affects air movement in and out of the cylinder. The "advance" cable you are talking about is actually the overfueler for the pump by pulling out to the first stop is overfuel, pulling out against the spring load on the stop is the shut off. A good sign that the pump needs work is that the motor doesn't try to shut down at high idle when going down a hill or wants to rev higher than spec rpm's. What color of smoke do you have at start up? White smoke on a cold engine is usually a clue that there might be a compression or air flow problem. I hope this helps
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
