Re: Newbie Questions......
Posted by BIG JOHN on April 09, 2004 at 16:31:57 from (205.188.116.213):
In Reply to: Newbie Questions...... posted by Michael Clum on April 09, 2004 at 11:47:13:
Sounds like you have a fuel delivery problem. The tractor runs out of gas and then after 5 to 10 min. enough fuel flows into the carb for it to run again. To check this remove the drain plug from the bottom of the carb. You should have a continious flow that does not taper off. If it does taper off to just a small amount then this is your problem. Where the fuel line goes into the carb there is a brass fitting that the fuel line screws into. Remove the line and then the fitting. You will find a screen filter that is probably dirty. If this doesn't fix the problem then you probably have dirt pluging the neddle valve and you will have to remove the carb and clean it. The carb is very simple to disassemble, clean and reassemble. GO FOR IT. GOOD LUCK
Home
| Forums
Today's Featured Article -
Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
