Re: Farmall 300 Propane Tank
Posted by MT Pockets on April 09, 2004 at 20:12:15 from (152.163.252.227):
In Reply to: Farmall 300 Propane Tank posted by Don Tucker on April 09, 2004 at 17:09:45:
Don, are you sure it's not Rego? If it's the original valves I think it's Rego, and they can be repaired as well as most other brands. Your LP gas supplier is who you need to see. The same kit will fit both the liquid and vapor valves unless one has been replaced with a different brand. Your tank will have to be empty. I hope thus helps. Steve.
Post a Followup
: Re: Re: Farmall 300 Propane Tank
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
