Farmall Tractors Discussion Board
Farmall 100 Touch control Hydrallic Lift
Posted by Paul Hodgson on October 23, 1999 at 16:43:43 from (216.38.20.1):
I need some help with a problem with hydrallic lift. Seems to have plenty oil. Will lift slowly and lower slowly with no attachment. Will not lift with two furrow plow attached. With control lever in raise position and rpm's high you can lift on plow and raise to any level and it will hold but will not lower wehn control set to lower even with added force. Would my relif vavle be stuck? What grade of oil is used in this reservoir? As you can tell I don't have a Manual yet. Any help greatly appreciated. Thanks Paul in Ontario
Post a Followup
: Re: Farmall 100 Touch control Hydrallic Lift
